come to think of it, its possible the headlamp movement came back when all codes were cleared prior to the APR going on..
That would explain why the following day they worked.
I did find something on VWVortex regarding the Comfort remote windows thing:
Polo9n.info
It states: The function works only with polos from 2001 to 11.2004. It depends on the communication of the control unit. With the older models this works via the CAN-BUS (up to 11.2004 FIN-9N 5-120000 or 9N-5Y120 245) and the newer (11.2004 - 2009) via the LIN BUS!
have not tested it tho.
also.. not sure if that contradiction when it states "will only work on 2001 - 11.2004" but then also says "the newer (11.2004 - 2009) via the LIN BUS!" is just something lost in google translate or not..
someone needs to test, I don't have a rosstech cable personally but I'll take the instructions into my VW guys and see if they can input the codes.
Hillbilly, i referring to the 9n3 mate, no idea about other 9n's or the 6r.
