What's it like having a de-cat? Does it rumble louder when down gearing?
Hi Guys Thought I'd just put a bit of info on my polo on here for you to see.
Mods:
Engine:
K03-0052 Turbo (K03s as opposed to the stock K03-0082 or K03)
NGK BCPR7ES Plugs Gapped at 0,7mm
76mm de-cat Down Pipe into stock exhaust
Forge Turbo intake pipe
Forge Throttlebody to Intercooler Pipe
APR R1 Diverter Valve
4 bar Fuel Pressure Regulator
PD160 Intake Pipe
K&N Flat pad Filter in Standard Airbox
REVO Stage 2
Recently (26 Feb 2011) did 178hp and 291nm at the Wheels With a Mild Stage 2 Map and Normal Pump fuel (95 oct).
Wheels & Suspension:
40mm Koni Lowering Springs
17" BBS CH Replica Wheels with Yokohama A-Drive R1 Tyres
SEAT Sport Top Strut Brace
Body:
Custom Badges (Red GTI and Carbo Fibre Front VW Badge)
Mat Black Front V
Gloss Black B-Pillars
Gloss Black Wing Mirrors
Colour Coded Rear Valance
Black Special Order Tail Lights
Chrome Boot Strip
Colour Coded insert behind Rear VW Badge
And here are a few Recent Photos.....
Comments Welcome
Yip it's a bit deeper, on down shift. but also sportier on wide open throttle, plus I gained about 10hp odd with the decat down pipe......
Are you going to decat the other cat aswell? As far as I know, the GTI has two catalytic converters.
Not as far as I know. It's only got the one cat thats in the down pipe....
the colour coded rear valance looks great
a 5dr pog.... NICE!!!
MY07 Polo GTi
Last run - 114.8kw atw
Winton - 1:52.7130
Larry, the car looks great. Love the wheels too.
Have you tried octane booster? REVO Stage 2 would probably prefer having 98 rather than 95 ron.
Can you recall any torque figures from other cars on the same day? how hot was it?
I was running REVO Stage 1 with down pipe and PD160 intake - and was running 183hp at wheels (after bit of heat soak as my car was the 1st one on dyno and there were setting to make sure things were okay) with 17" heavy RS4 replica wheels / it was 22 degrees that day.
I now have REVO Stage 2 / Forge 007 spring strength also increased / 4bar / will get new spark plugs next week - I am hoping to get 195hp at wheels. I have also returned to my original wheels as they are lighter.
Maybe next dyno, try better fuel / and check what the peak boost was at? I also have a 4 door - I love it.
06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
