Page 5 of 15 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 149
Thread: KO4 Turbo review
  1. #41
    Nov 2008
    The APR kit is turbo, 4bar FPR and different software only.
  2. #42
    Jun 2008
    Perth
    Pogo55 - how do you find the wheel spin for day to day driving? As guy states - its takes getting used to but is quite controllable. Is it just a case of altering you driving style?
    Also if you could get you money back and return to the KO3S...would you? (sorry probably a stupid question)
  3. #43
    Nov 2008
    In my opinion driving in traffic, particularly rush hour traffic is where it has a big advantage. With the chipped Polo I was always aware of having to be careful that the revs didn't hit the point, around 2K where the switch flicked and it launched forward when there was a car immediately in front of me. The power delivery with the K04 is much smoother, even my wife commented on this after it was done. If you drive it with the esp on, then really the wheelspinny thing does not come in to it. However for a month after I got it done my front wheels seemed to be permanently covered in brake dust. At first I couldn't understand it as I was not braking much harder or more often than before. Then I tried switching the esp off and the brake dust returned to the normal amount. So the esp is interfering more now than before. It certainly goes better, particularly in second with the esp turned off. With the esp off, as flaps said first gear is pretty useless, and if you want to spin it through second you can. Although I'm sure you could also do this with a chipped one if you tried. Yes, under full power it probably will wheelspin more than just a chipped one, and I probably don't think much more power than this on the street would be helpful.
    No I wouldn't want to go back to the K03s as the power delivery (not to mention the greater power output) of the K04 is much more like a factory produced effort than the chipped K03s with its boost coming on like a switch. The petrol consumption is at least as good as the chipped K03s under normal driving conditions. I purposely never attempt to calculate the fuel consumption after a good caning, but as it has a bit more power it probably would be slightly worse than the K03s.
  4. #44
    Jun 2008
    Perth
    thanks heaps Pogo - just the review I was hoping to hear - SOLD!!
  5. #45
    Mar 2009
    England (UK)
    so if i get a k04-001 turbo slap it on and a 4bar pressure reg and a new custom map thats all i need extra from what i got now?? i heard this maf topps out with the 04?? can some one confirm what i need to do thanks!
  6. #46
    Jan 2009
    sunshine coast
    yeah im pretty sure the maf, due to higher air flow, cant read properly and throws a code. sorry unsure how people got around this.Guy from h/p would definatly know as would flaps since he has a k04.
  7. #47
    Jun 2007
    If you're considering a KO4 upgrade, the first step is working out which K04 tune you're going to use to run it all. Most tuners specify exactly which parts are needed for their k04 upgrades - that's the best way to approach it.
  8. #48
    Nov 2008
    Chris,
    Yep that's all you need with the APR software. Mine has had a vagcom connected to it several times since the K04 and no maf errors, so I guess there is some smart, or not so smart code in the software to handle this. Guy Harding is the man you would need to talk to for details. If you're around Guy, I would like to know about this too.
    The kit is listed here:
    http://www.goapr.com.au/products/turbo_k04_vw.html
  9. #49
    Mar 2009
    England (UK)
    right apr dealer in uk doesnt have this kit listed, anyhow im gunna source my own parts turbo etc but they can get the map off apr server for me from aussy, plz can someone list the parts extra needed exactly so i can get on with buying bits .
    thanks chris
  10. #50
    Dec 2008
    Curitiba/PR, Brazil
    Quote Originally Posted by Chrisuk-polo View Post
    thanks chris
    Turbo, hi-flow exhaust manifold (not needed, but recommended) and a 4bar fuel pressure regulator OR 36lb/h injectors (TT225 0280156063).
    SILVER TEAM
