Page 5 of 5 FirstFirst ... 345
Results 41 to 48 of 48
Thread: KO3 or KO3S ?
  1. #41
    Feb 2008
    Quote Originally Posted by ATPG View Post
    My experience would say the polo Gti only has the K03s on it.
    both in 150 and in the 180 bhp form.
    Difference in the K03 to the 's' is the 's' has the 8 blade compressor wheel and the K03 has the 12 blade. Inducer size is 2.1mm bigger and exducer is 1mm larger i think.
    Never ever seen the polo with a K03 on it.
    And here I was thinking a letter from the manufacturer stating that there is no KO3S would be a definitive answer... How I was wrong...
  2. #42
    I guess the fact that everyone labels it as the 's' is good enough for me. At least people know what you are talking about when you talk about the K03S.
  3. #43
    Jan 2009
    blankedy
    Yeah, I wanted a k04, but can't afford one, so i tell people it's the 'S', it's practically a K04....
  4. #44
    Feb 2009
    Jozi!! South Africa
    Ive had this discussion on this forum before, the PGTi(mine) does have a K03s, im not sure if its only in South Africa our Polo turbos kept breaking possibly due to the altitude in JHB. My tuners confirmed I have a K03s hence my massive gains on a phase 1 map.
    Heres a link confirming turbos on VAG cars.
    The K03s has a larger diameter inlet and outlet.
    thread
    http://www.vwwatercooled.org.au/foru...tml#post360568
  5. #45
    Feb 2008
    Now, I'm stumped about what I should believe...
    Dear Sir,
    thank you for your interest in our products.
    First of all, we don't produce any turbo that we call K03S. But I hope I can
    answer your questions with the following explanations.
    All the following turbos have the same installation dimensions and
    thermodynamical performance. The differences are only in the actuator that
    opens the turbine bypass valve:
    K03-011 (5303 988 0011) 150 hp, 65 N actuator
    K03-026 180 hp, 85 N actuator
    K03-035 180 hp, 85 N actuator
    K03-044 150 hp, 65 N actuator
    K03-045 156 hp (Ibiza Cupra), 85 N actuator with 2 ports
    K03-049 150 hp (Sharan/Alhambra), 65 N actuator
    The 180 hp versions have an actuator with a higher opening force due to the
    higher exhaust gas pressure (which is a consequence of the higher boost
    pressure). Otherwise the valve would be pushed open by the exhaust gas
    pressure.
    The following turbos are a further development (since 2000) and have an
    improved and slightly larger compressor while using the same turbine (still
    with the same installation dimensions):
    K03-052 180 hp, 85 N actuator
    K03-053 150 hp, 85 N actuator
    K03-058 150 hp/180 hp, 85 N actuator
    Consequentially, putting a 180 hp turbo on a 150 hp engine will not bring
    about any change in performance, but putting on a K03-052/053/058 instead of
    the older versions will bring a slight improvement in engine efficiency.
    Additionally, with re-mapping the ECU you can achieve about 215 hp without
    danger of overspeeding the turbo. With the older turbos, 195 hp is the
    limit.
    With the K04 that's also commonly used (5304 950 0001) the power output
    should not be more than 220 hp. That means, changing a K03-052/053/058
    against a K04 does not make a lot of sense.
    I hope that these details answer your questions. If you need more info, one
    of our service distributors will be glad to help you. Their addresses are on
    our website TurboDriven.com - BorgWarner Turbo Systems.
    Mit freundlichen Grüßen/Best regards,
    BorgWarner Turbo Systems GmbH
    Sales IDS - Technical Support
    Christian Seibert
    Quote Originally Posted by JK8 View Post
    A letter from the ACTUAL manufacturer of the of the turbos stating that there was NEVER a KO3S, or a random list...
  6. #46
    Feb 2009
    Jozi!! South Africa
    I had pics of the K03 next to a K03s, they do exist.
    Quick Google
    http://audittmk1.blogspot.com/2008/0...s-k04-etc.html
  7. #47
    Feb 2008
    Quick Google
    The Mk1 Audi TT Enthusiast Guide: KKK Turbos - K03, K03s, K04, etc...
    I once again refer back to the letter from the manufacturer... I would tend to take his word rather than an enthusiasts website.
  8. #48
    Jan 2009
    blankedy
    I've not seen any info that would make me think an early 9N3 had a different turbo to the newer ones.
    Not to say the parts are identical, there may have been different batches, minor revisions, etc.
    Given the parts are BW and there does not seem to be any dovecote from them using the 'S', fair to say its likely just the newer model terminology.
