Results 1 to 10 of 10
Thread: Ko3 hybrid
    Jun 2013
    Huddersfield England UK
    Ko3 hybrid
    Dose anyone on here run a ko3 hybrid ?
    I have some BAM injectors unsure if they will be good Enough to run 280 bhp
    Sent using tapatalk
    Feb 2007
    Brisvegas
    What's the rating on the injectors mate? It's usually determined by the tune you're going with as to how much flow you need.
    Sep 2010
    Wheelers Hill
    Re: Ko3 hybrid
    Aren't they the s3 injectors, I think they're like 330cc
    Sent from my GT-I9505 using Tapatalk 2
    Audi A3 1.8 T
    aiming for 200kw atw
    http://www.vwwatercooled.com.au/foru...-8t-71747.html
    Feb 2007
    Brisvegas
    380's rings a bell also. And I think that's the very minimum for a hybrid tune.
    S3 injectors are 386cc at 3BAR. Pretty close to the limit if you do make 280.
    Speak to your prospective tuner first Luke, we/they all have different ideas on how to go about tuning.
    Mar 2013
    melbourne
    May be cheaper to get a s3 K04 - i got quoted 450, if you are going hybrid k03, you may as well go all the way on the turbo (same price as a mild hybrid),then port the turbine housing and exhaust mani, and that should get around 310-330, check out Badger 5 in the uk
    Quote Originally Posted by Eski View Post
    An S3 K04 is a different beast to the K03s and would require a change of downpipe to suit it. So an additional cost and no off the shelf downpipes that I have heard of.
    Mar 2013
    melbourne
    Right you are gav, Assuming you want to go the easy route and buy a miltek system (given you are in the uk) , S3 turbo and the Frankenturbo right angle downpipe adapter may work.
    But considering you are in the uk , there are a bunch of turbo companies that hiflow and have gotten results., CH, badger would be good to use. and overall easier/better solution although it may be a bit more expensive.. even frankenturbo?
    Jun 2013
    Ko3 hybrid
    I had a ko4 but it turned out to be a copy and no good :/
    Maybe genasis 550cc injectors would be better then
    The only reason in not going for big power is that I don't fancy doing the rods and pistons at this stage
    Sent using tapatalk
    550cc are a fair bit of overkill. Anthony has 500cc in his Polo and there's plenty of head room even at 3 BAR.
