Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: K04 - Which one and how much?
    Jan 2009
    blankedy
    Don't tell my wallet, but as I've done most of the other required mods, thought I should see how much a K04 is.
    So, I believe the K04-001 is the one used in conjunction with the APR tune?
    Can a different K04 be used with the APR tune?
    I'm seeing K04's for about 250 - 300 pounds, which would be somewhere around $600 landed, obviously I'd need to make sure they are legit, is there something I'm missing here?
    Is installing a new turbo a big job (for a mechanic)?
    Jan 2009
    Bucharest, Romania
    As I know, the K04-001 is the most "popular", because it's a bolt-on replacement of the K03s.
    get Dom's T3 and get some REAL hp !
    EDIT: and custom code that shiz!
    Fitting the turbo isn't that hard, you need to take the right driveshaft out to make it much easier to access.
    Don't kid yourself into thinking it's a cheap upgrade, unless you can do it yourself.
    I thought APR had K04 software that was free/cheap. It'll work on the std software but certainly won't be running at it's best.
    To truely get the most out of it, you need to emulate hardware of the K04 equipped factory cars, like the 8L S3.
    pogo55 has one, I reckon APR fitted it in Brisbane.
    Beware of Chinese turbo's, can not Guarantee the result with those - buy a genuine Borg Warner KKK K04.
    Talk to your nearest APR dealer about software upgrade!
    Sep 2006
    Have you looked at the APR site
    I think if you supply all your hardware, turbo etc they charge you about $700 for the software
    It you buy the turbo etc from them the software is free
    Do you need a new manofild or does it bolt straight on
    Can someone tell me how much power you would get over the K03 with the same mods, exhaust etc 40hp??
    Feb 2007
    Brisvegas
    Quote Originally Posted by vwthunder View Post
    I was at a dyno day where a polo had DP, Intercooler, APR K04 with software and it pulled 169 HP atw on a Dynomatics dyno in non shoot out mode. Hope this helps!
    Quote Originally Posted by VWindahouse View Post
    i think dats alittle low for a car with k04
    Quote Originally Posted by AGO41T View Post
    That's what it made on the day though. It has standard MAF and injectors.
    Feb 2007
    Brisvegas
    As I said NON shoot out mode
