As you stated it may not give you much more POWER, but it should give you better throttle response. I guess the 1.6 is the same as any other Normally aspirated motor, in that if you upgrade the intake AND exhaust it should give you a little bit of power. Have a look and see if any O/S companies make extractors. even a cat back exhaust would help.
