I've found with my GC's that the solid top mount makes surprisingly little difference on normal bumps but you REALLY feel it on larger sharp edged potholes and bumps.
I doubt 3mm of rubber would make much difference at all in these cases but it would be interesting for someone to try with and without this.
Resident grumpy old fart
