Page 10 of 15 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 144
Thread: K-MAC front Camber and Caster adjustable Top Mount Group Buy
  1. #91
    Feb 2007
    Brisvegas
    Quote Originally Posted by Stuwey View Post
    Too much which way? Generally you'd have a pinch of toe-in for the street. It helps give some straight-line stability.
  2. #92
    Oct 2010
    Melbourne, VIC
    FWD normally have a touch of static toe out since the wheels being driven will pivot the control assembly inwards.
    Quote Originally Posted by VWindahouse View Post
    I think I may have a little to much toe at the front. Seems to be a little uneasy getting over 100kph.
    Your toe figures look fine. How much rear wing are you running? Or could it be bump steer?
    Resident grumpy old fart
  3. #93
    Quote Originally Posted by kaanage View Post
    Too many lows/too much offset/too much rubber?
    Cheap, Fast, Reliable. Choose two.
  4. #94
    This is what I thought. Was explained that under power the wheels effectively pull themselves to be parallel.
  5. #95
    But surely on highway cruising this isn't the case?
  6. #96
    That's true and where my aligning knowledge stops.
  7. #97
    Feb 2007
    Brisvegas
    Nope wing and general high speed felt perfect before strut tops and alignment. However just had to replace the sway bar end links cause one was busted and just had a look to find they only put the front sway on medium not hard so its thrown the feeling I like and are partial to out of kilter. Will put it back to hard and see how that feels. So my front toe is ok?
  8. #98
    Sep 2006
    My ones still haven't arrived yet!!
    Called Kevin today, said he is sending them out to me today, which i have heard before, was also saying something about asking Junior about if he had a spare set, did he send my ones to the UK ? How many were ordered to the UK ?
    MODS- TOO MANY
  9. #99
    Sep 2006
    Oh off topic, but can people who are on UKpolos vote for me for polo of the month
    UK-POLOS.NET • View topic - February 2013 Polo of the Month - VOTE NOW!
    Seems that they would rather a Stock 6r with a set of black wheels be polo of the month than me
    MODS- TOO MANY
  10. #100
    Oct 2010
    Melbourne, VIC
    The wheels still have to pull the car against the drag on the body.
    Hmm. That should increase front end grip so you should then find the car oversteers more, so yeah!
    It doesn't look at all excessive
