Results 1 to 10 of 18
Thread: Just got a 07 GTI. Have a few questions.
    Question Just got a 07 GTI. Have a few questions.
    Hi all,
    A month ago I picked up a red 07 GTI with 100K km's on it. Stock except some poly front control arm bushes. Im loving it so far. I've been reading a lot on these Polos and trying to learn as much as possible so I can plan my upgrades well.
    I have a few questions I can't seem to find the answers to no matter how much I search.
    1: Does the GTI have a low washer bottle level alert on the dash? The manual I have says it does, but mine never seems to come on?
    2: What is the best Ross-Tech cable to buy? And what are the options for Polo's? There are so many different types and searching has me very confused.
    I'm mainly wanting to be able to check codes, easily reset the service indicator, do some data logging. I have a cheap eBay one on its way from China which hopefully will allow me to check codes, but know I will need the proper one in the future.
    3: What is the best data logging software?
    4: Has anyone bought an IC from these guys? Seat Sport Intercoolers | UNIVERSAL-INTERCOOLERS . Looks the goods and is quite a bit cheaper than Darkside Developments.
    My main plans for mods are
    Dump Pipe (Custom)
    Seat Sport IC
    CC Stage 2
    SuperPro Dogbone
    Whiteline Rear Sway Bar
    Either Bilstein B12's or MCA Blues
    Luke
    Jan 2009
    Welcome.
    Qs 1. I've never seen it show a light on my car in 7 yrs, so guessing no light for low washer bottle.
    Qs 2. If you have an ebay cable, you can try the VCDS Lite version (freeware) to make sure the cable works, beyond that you need to buy the license for VCDS Lite (US $99) or need to buy the full version with their cable for $250 or something.
    Qs 3. For data logging, I find ME7 Logger much more powerful than the logging capability of VCDS. Check out netfarious. It's sample rate can be up to 20 samples per second across 60 parameters. It takes some fiddling to get it configured.
    Qs 4. I have a Seat Sport cooler on both my cars and many people run them. They are good value for the money. They offer a great balance between pressure drop and cooling charged air.
    sean
    Daily: 2010 VW Jetta Highline
    Thanks Sean!
    I've been researching VCDS more. It looks like I would want the KII-USB one, but could also use the HEX-USB+CAN. Is there any benefit to the second option beside being able to use it on future VAG cars if I upgrade from the Polo?
    Is VCDS Lite as full featured at normal VCDS? I assume not, but what are the main limitations?
    For ME7 (I haven't looked at this at all yet) can i use the eBay cable or do i need the Ross Tech one?
    I am definitely planning on going the Seat Sport cooler for ease of fitting and neatness, but was mainly wondering about that particular seller. Being so cheap compared to others makes me wonder if its the real deal or not :/
    Luke
    May 2015
    Blackburn, Vic
    Quote Originally Posted by Slow_Polo View Post
    I'd also be interested in this - let me know if you want to combine for cheaper shipping
    I noticed no pipework done with this - do they also provide kits - or someone else that could provide a kit? Or would it all have to be knocked up.
    Quote Originally Posted by Julzaac View Post
    You only need one pipe fabricating, with the MAP sensor boss in it.
    Otherwise the rest of it can be put together with off the shelf parts.
    Will do Julzaac.
    Do you have any MAP pipes left Gavin? I seen you had a few made up previously.
    Sent from my XT1068 using Tapatalk
    Will do Julzaac.
    I have one I was saving for a guy, that was a year ago, so I guess you can have it. Usual price.
    email me from my sig, gmail.
    Jan 2009
    Thanks Sean!
    Luke
    There are some differences between the lite version and full version, though I believe it still provides significant functionality so unlikely to be short changed. For "check codes, easily reset the service indicator, do some data logging", the lite version does all that. I don't know what the limitations are of the lite version.
    For ME7, the ebay cables are fine/best. If you were to buy a genuine Ross-Tech cable, you need to run it in dumb mode, so is effectively the same as the ebay cable at that point.
    Sorry, I don't know about that intercooler seller. I have a vague feeling I got mine from Darkside Development, can't recall 100%...
    Feb 2015
    Auckland, New Zealand
    That sounds promising...
    Any idea what is required?
    Quote Originally Posted by amdeman View Post
    There's 2 threads floating about if you go back far enough.
