Update
Another fellow 9n3 buddy came around today to get his mk5 golf steering wheel installed and tried fixing a few of his issues with his recently purchased GTI
HVAC only runs when dial is turned to number 4 and the error code is 01596, motor for outside/recirculated air flap open or shorted.
I have an idea where it is but involves dismantling the whole dash to get to it/replace it. Output testing didn't fix it and I believe the wires are fried if not the motor is gone.
Mentioned to him that rocker cover is slowly doing the same as the other Polo that I'm yet to put back together and CV boots be slightly leaky. Oil was low(topped it up after) and engine was making a funny knocking noise, check up on VCDS and suprise suprise, cyl 1 knock sensor be giving a higher voltage than the rest. Oil made it a bit better but still not 100%.
After he left, continued on the rear bracing and got that finished!
Also finished installing my rear dash cam after oh so long due to breaking the first cable head's and dinting my quarter panel outwards when it got jammed without any way of retrieval
Need to get PDR done on the car once it's all ready, but as I've been told by my mate, $50 a hole(professional shop) it really does add up..
That's about it for today.
Got to not simulate the brace onto another 4 of them so they can fit for others and then get them all professionally powdercoated.
Then fit my watermeth kit, run the cabling so it works because right now it's sitting in my car.
Start putting back the other Polo and getting that sorted.
Have a Subwoofer planned, as well as looking for a headunit that'll sit in the nugget holder up top of the dash. Want to get the steering wheel controls in, so got to go wreckers and get the upgraded airbag cable going into the clock spring as well as the ones that clock spring plugs into.
After all that:
LED taillights, VW infinity mirror badge I like the idea
Custom Number plate, I hope nobody takes it within the next month or so
LSD in November when I have time to sit to do it.
Bluemotion/any bodykit, but that'll be something for heaps later probably.
Sam!
So the injector currently in the spacer is 200cc, I've got two more that I discovered today which looks smaller and bigger, than the one I have in the car now. SO, will get a bung to weld into the aluminium piece that has the map sensor on it. Should be enough space to fit everything. Will experiment with plug gaps if that will help in any way as you mentioned.
Gary!
Now that you've mentioned it, I actually don't mind the idea! I have two united petrol stations quite close to me and I fill up at either quite regularly, so it would be a suitable idea, will talk to Gavin and Dave about that soon.
