Don't think APR do a stage 2.
Happy CC stage 2 customer here. I had the SAI CEL deleted as part of the tune.
08 9n3 Polo GTI
Mods: heaps
Daily: 2010 VW Jetta Highline
It shows Stage 1,2,3 on their website i will have to inquire further then. a Stage2 tune which ever route i go wont happen for a while anyway i want to get all the other mods out of the way + probably a FMIC too.
I went with this one Mini ELM327 V1 5 OBD2 II Bluetooth Diagnostic CAR Auto Interface Scanner AU | eBay it was bloody cheap but does the job. as for logs i know the app lets you overlay and record guages, stats etc for tracks as for logs im not to sure i havnt got that far into it yet works been killing me.
2006 Polo GTI | APR Stage1 | PD160 | K&N Panel filter | Forge TIP | Forge DV | Forge IC Piping | Milltek TBE |
| Forge Front/Rear Strut Braces | SEAT RCA Bushes|
No EGT in the Polo unfortunately. A std sidemount would be overwhelmed pretty easily. Seat Sport is my recommendation for a FMIC. Needs a pipe kit but I have the MAP sensor pipes available. THe rest can be bought off the net.
APR stage 2 is K04
CC stage 2 is desinged around a dump and FMIC. CC coding out the SAI is one of the reasons I went down that path, the APR option was too cost prohibitive.
Very happy with CC phase 2. Im near North Sydney if you wanted to see for yourself
Iv found that while driving my gears have become "sticky" no crunching and gears select fine. Will be changing the oil tomorrow and see I'd this fixes it. Also noticed some chattering when the clutch is not pushed in at idle from what I have read it's just because of a single pressure plate instead of the stock double and won't cause any damage? It's a ECS stage1clutch.
ECS can chatter, I wouldn't be concerned.
