Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Josh's Polo GTI
  1. #21
    Jul 2014
    So i did the Gearbox Oil today and im glad i did it was BLACK and it STUNK! i couldnt source any Redline MTL from any shops in my area on a sunday so i went it Nulon + Shift additive. its due for a service in another 10k kms anyway so i will change it again then with some Redline and hopefully the Nulon i put in it will act as more of a "flush".
    Few snaps i took while doing it.
    Josh's Polo GTI-gopr0587-jpg
    Josh's Polo GTI-gopr0592-jpg
    2006 Polo GTI | APR Stage1 | PD160 | K&N Panel filter | Forge TIP | Forge DV | Forge IC Piping | Milltek TBE |
    | Forge Front/Rear Strut Braces | SEAT RCA Bushes|
  2. #22
    Jul 2014
    Got my hands on some Redline MTL flushed out the nulon after 1000kms. after the first 100kms i really noticed the difference with redline.
    Finally decided whether or not i wanted spring/shock combo or coils. I opted for H&R springs not sure what shocks im getting atm. reason i went that way is because i don't mind the ride being bumpy or a bit stiff, even if i got hassled by the cops, but the wife really didn't want it to bumpy and if she drives it I don't want her getting hassled + i called aami and they said it "may" void my policy having adjustable.
    so i got some H&R Springs on order soon to decides on shock.
    ultra racing rear sway bar.
    new gearbox mount.
    all should be here by mid September.
    pretty set on getting a set of XXR530 17x7 +35 wheels. unless i find a set of Enkei RPF1's.
  3. #23
    Jul 2014
    Very inactive and thought i would update.
    Some TT ronals finally on.
    Pod in a box, red coils and diy laser cut adaptera for them. 6mm stainless painted red.
    Laser cut a pod cover as well. Painted matte black
    Digital boost gauge mounted on the steering column.
    Also have done braided brake lines, slotted and dimpled rotors front and back with euro+ pads.
    Sent from my SM-N910G using Tapatalk
  4. #24
    Dec 2012
    That's a very neat pod filter setup been thinking of making something like that myself even with the cover on do you still get more induction noise?
  5. #25
    Jul 2014
    Quote Originally Posted by LZY13B View Post
    it made it slightly quieter but would rather avoid trouble if possible lol. cane still definitely hear the induction noise.
  6. #26
    Neat looking Polo!
    What size tyres did you end up going for the TT wheels and how much did they set you back?
    Ive got some TT wheels that I restored and contemplating putting on but not sure about the comprise in ride comfort.
  7. #27
    Feb 2014
    Gold Coast, Queensland
    Nice mate! The laser cut bits look the goods!
    Any idea what the CEL on the dash is for?
    2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
  8. #28
    Jul 2014
    i got 215 40 tyres, ill probably be flamed but they are just cheapies so i could get them onto the car and get them painted. you can feel the road slightly more over stock but definitely more grip and feels more stable.
    the CEL is from p0411 SAI its been removed but i havnt gone to get it coded out. im use to it there now lol.
  9. #29
    Jan 2009
    Quote Originally Posted by rbalc1 View Post
    Neat looking Polo!
    The other consideration is that the TT's rims are a heavy wheel. You may notice the increased weight over the lower profile. You could run a 45 series tyre too, it'll bring the speedo closer to accurate at 100kph and should be bang on at lower speeds. Just be mindful of your ride height if going 45 series, if lowered it may hit the underside of the inner guards. My track tyres are 215/45/17 and had to raise the front up a bit as to not touch under heavy compression.
    I now run the TT rims as my daily's on the track car after using them as my track rim. Got the refurbed and looks brand new.
    Daily: 2010 VW Jetta Highline
  10. #30
    Jul 2014
    Yeh they are pretty heavy. My coilovers arnt in yet and was scared 45s would scrub in on hnr springs atm. Once i sort some "proper" tyres and get my coilovers in i will see how i want to go about it.
