Results 1 to 10 of 14
Thread: Iphone on Polo Stereo
    May 2009
    Hi Guys,
    did a search but couldnt find anything specific.
    Two things, I just bought an Iphone and want to use it in my Polo GTi. I have a mate with the stereo integration thing leftover from his Mk5 Golf so I can get the components cheap.
    So
    1. Does the Ipod adaptor work with the Iphone?
    2. Do I have to get VW to install the adaptor or can any shop do it (warranty runs out in 2 weeks)? Or even can I do it myself? Has anyone else installed it themselves?
    The number on the package to confirm parts is 1K0 051 444.
    Any help appreciated.
    06 > 9N Polo GTi
    Feb 2008
    Perth, WA
    cant comment on the above sorry but i can advise to lose the OEM deck and put in an aftermarket one!
    I run an eclipse headunit...iphone wirelessly plays tunes/phonecalls through stereo via bluetooth...no cords/docks to worry bout...have also got an ipod adaptor/USB in the glovebox - can't recommend it enough
    South West Sydney
    Quote Originally Posted by Bluey9N View Post
    Hi Guys,
    1. check out http://www.vwwatercooled.org.au/newf...ghlight=iphone
    for number 2:
    I remember asking this question myself some time ago. If you plan on doing it yourself, from memory you'll need the dash keys, and you'll need to dismantle large proportions of the whole dash.
    Sep 2006
    I have the Ipod adaptor but it dosent charge my Ipod touch
    MODS- TOO MANY
    Mar 2009
    Apparently you get close to no control of your iPod/iPhone by connecting it to the factory connecter in the Polo.
    I'm looking around for something like this http://www.xcarlink.co.uk/product.ph...4&cat=2&page=1 available locally.
    There is http://www.xcarlink.com.au/index.php...a239d84c41d080 but i'm not sure if they're compatible with the iPhone 3GS....actually, i'm not even sure if the model in the first link supports the 3GS either...
    I'm finding it a tricky process to get what i'm after here in Aus: an adapter that allows me to control the 3GS via the radios buttons while charging the iPhone & supporting the use of a bluetooth device, which i'm thinking of adding in future.
    MY16 MK7 Golf GTI
    - Manual - Sunroof - Folding Mirrors - Lock/Unlock Chirp - 4x Indicator Flash - Traffic - MK7.5 LED Tail Lights with Sweeping Indicators - Dynablink Sweeping mirror LEDs - White LED's on rear rego plate -
    Feb 2009
    Quote Originally Posted by vwthunder View Post
    You need one of these (or similar, there are a few companies that make them):
    http://www.scosche.com/products/sfID...productID/1667
    May 2009
    I pulled the kit out of the plastic and plugged the Iphone into the connector and the phone flashed up "this product is not designed to work with the Iphone, do you want to change to airplane mode?"
    Pretty sure Ill just keep burning CDs.
    Thanks for the links and stuff guys.
    06 > 9N Polo GTi
    I use a Connect2 adaptor for my mp3 player. It connects to the CD changer controller on the headunit and has a simple earphone jack to plug into the MP3 player. Does the job and was inexpensive.
    THey have this for iPods
    CTAVGIPOD009 Connects 2 Ipod Adapter - Apple
    VW Passat/Golf/Touareg/Touran
    Delphi/Blaupunkt
    Delta 6/RCD200/300/500
    Feb 2009
    Nearly all iPhone connnectivity devices for cars do that. Just click no and it will continue as normal. Even the VW MDI generates the same prompt.
    Feb 2008
    Perth, WA
    +1 for 'click no'...mine still won't charge it though
