Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 86
Thread: Intercoolers and for Polo GTI and TDI...and other products!
  1. #41
    Jan 2008
    Cremorne, Melbourne
    Quote Originally Posted by shaneth View Post
    i cant see the metal colapsing but it is a pretty sharp and restrictive turn on the metal part as it mounts on the turbo. The pics show a silicon pipe of sorts.
    yeah i know, i'm wondering if that's all part of the price....will find out soon i s'pose.
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
  2. #42
    Jan 2008
    Western Sydney
    credit to Guy Harding for this picture.
  3. #43
    Jan 2008
    Quote Originally Posted by [-Polo GTI-] View Post
    please explain how a metal cylinder collapses under boost and a flimsy plastic part doesn't
    The part that is made from flimsy plastic is like that because it doesn't need to be strong. Closer to the turbo where it turns quite sharply and gets smaller is where the pressure is.
    'Collapse' doesn't necessarily mean it's blocking off, just slight movement.
  4. #44
    Nov 2008
    Wembley, WA
    Quote:
    Originally Posted by mozzzy_2000
    Ok I'm a little lost. Is this steel turbo inlet pipe in addition to a forge TIP or does it perform the same function? Also this may be ignorant but wouldn't a steel inlet pipe get hotter than a rubber/silicone pipe? Have these been tested in the 'real' world?
    as far as i can see it performs the same function. have not checked about real world figures, those questions will come soon (see my next reply for more). as for steel piping, same could be said for intercooler piping and why it isn't all silicone. i'm not sure about the heating, but if the price is right i'll be happy to guinea pig it and let you all know. i would have thought the constant air flow would have been enough to keep it cool, it doesn't really sit in the pipe for long. also, i would imagine there would be faster air flow through steel than silicone.
    I can see your point. I suppose there are prons & cons with different materials. The point I was thinking though is that I would have thought the hot metal would heat up and stay hot and also absorb heat from the engine bay more than a silicone pipe would and thus the air intake is much hotter air reducing your power. Of course it may not function like this in real terms but I was just wondering that one of the reasons the Forge TIP works so well is that it is replacing the metal section that bolts directly to the turbo and being in silicone, it would stay cooler and not transfer as much heat to the turbo itself. Again I could be wrong but its a theory.
  5. #45
    Nov 2007
    Quote Originally Posted by Grant View Post
    The stock TIP collapses (as in almost totally closes up) under high boost in the plastic part just above the metal bit.
    Looking at the pictures of the SA TIP, it seems to be a 2 piece as well. Metal at the top and silicon at the bottom. Is it any better ? Probably better than stock, likely worse than a Forge TIP. Even APR made a TIP and gave up selling it in Oz as it did the same job as a Forge for more $$$$.
    It is likely to be very expensive shipping to Oz and customs will have a good look at it since it is metal in parts. I'd be surprised if it came in at under $200 each.... of which shipping is likely to be $100-150 each...
  6. #46
    Jun 2007
    call me a spedstic,
    but how is the Short Ram intake configured? Looking at the picture, I am lost.
    where are they getting the ram air from? because from the intake box to the front of the car, the OEM is at a straightline (almost) how do they shorten it?
  7. #47
    Nov 2008
    So the one on the left is our stock TIP ?? **** it is narrow in comparison.
    Also, is it just distortion in the pic or does the metal section of the stock TIP actually taper where it joins the black rubber ? I wouldn't have thought it would, but the pic makes it look that way.
  8. #48
    Jan 2008
    Yes the one on the left is stock.
    And yes the stock TIP does taper at that point.
  9. #49
    Feb 2008
    This picture can probably show the differance between the stock and Forge TIP's a bit better. This is from when I did my own install on my car.......
  10. #50
    Aug 2008
    I had a quick look on the website and if you go through the checkout you can calculate shipping. Total price (inc shipping to Sydney) worked out to be AUD $94.00 so if that is the case I'd be willing to give it a go (will take a few weeks until I've got cash again though. Bloody xmas!).
    It may not end up being as good as the Forge TIP but for more than half the price I think it's worth a go and it has to be better than the factory one.
    Cheers,
    John
