Kai did it to his Polo, ask him about it. IIRC he diverted or split the water hose for the window washer jets, then ran it to the IC. then when he flicked on the spray jets, it would spray the cooler. i suppose you could set up some sort of tap/vavle to change it from full window washer jets to full cooler spray.
for the actual spray pipe below the cooler i suppose you could just use some sort of tube (similar to the hose used for the washer jets) and just put some holes in it. i'd imagine the hose would need to be at the bottom of the cooler otherwise it would leak out. I know this may sound a bit 'captain obvious' but i could imagine some people would do it thinking its better as water spraying down would cover more area
EDIT: i see you have changed your post to add in the part about the alcohol/water mix. well, you wouldn't want to be spraying alcohol over your windows now would you.
Officer: "Don't lie to me, I can smell alcohol all over you!"
Sharkie: "No sir, it's my windows, I promise." *sprays cop with alcohol* "See!"![]()
