I didnt know physics had a intercooler water spray subject?
Do you honestly think it would make a tangible difference?
FOR SALE
"VW GTI" QLD Prestige Plate
Go get a water spray bottle, fill it with hot water.
Stand in front of an air conditioner on 30 degrees and spray the water (on a fine setting) a few inches in front of your face.
I bet you the water feels cool despite it being hot and the air hot.
I have no idea how much difference that would make to a car in terms of power though.
FOR SALE
Put metho in the water and it gets colder quicker.
FOR SALE
FOR SALE
You'd be foolish to not upgrade the intercooler if heat really is an issue.
Sure, water spray is a fair bit cheaper, but its limited by the water you carry, and is a band aid fix to what is a cooling issue that should be addressed by other means.
Not to mention, you'd be nuts to go water instead of a cryo based system either way (I know many of the WRX guys go for the Cryo2)
Edit:FYI, any water spray kit would be next to useless of it just sprayed the water onto the intercooler in a stream. The thermodynamics of the process require the water to be an incredibly fine mist (even drops are too big, it needs to be pure mist) in order to cool effectively.
Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
Current Ride: Evo 8 MR, Fabia MK3
The point being made is the cooling effect gained when a fluid evaporates, as stated it is simple physics. If you get your hot cup of tea and atomise it into a fine mist in a cool air flow and spray it onto a hot suface where it evaporates, you will get a cooling effect. Obviously cooler water will give a greater cooling effect but within limits, even if the under bonnet temperature does warm the water up there will still be some cooling effect.
George
06 Jetta 2.0TFSI Killed by a Lexus!
09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
14 EOS 2.0 TSI has arrived!
All I need to know is that it doesnt work very well.
This comes up in every turbo forum and gets shot down.
As said above, its a band aid fix.. you want cooler intake charge, get a better intercooler.
