Results 1 to 10 of 10
Thread: intake help suggestions?
    Mar 2008
    NSW
    Hi guys,
    Im trying to DIY my own seat intake. Ive got some larger tubing but
    unsure of how I'm going to mount it to the grill area at the front
    of the car. Any suggestions?
    I've arleady got a K&N panel filter....
    Thanks!
    Brendon
    Mar 2008
    NSW
    bump.......
    no ideas at all?
    cable ties
    Jan 2009
    WEst Sydney
    heres an idea...
    leave the stock intake to front of car and add your tubing under the stock airbox to get additional air from underneath the car..
    looks nice n stock from underhood but you add an extra air feed from underneath.
    Mar 2008
    NSW
    Quote Originally Posted by Petrina Polo View Post
    heres an idea...
    hmm have you tried that? What about rocks or anything that might pull into the airbox?
    Nov 2008
    Quote Originally Posted by shhplit View Post
    I think you're unlikely to get rocks up there ... it isn't a vacuum ! Also, anything that does get drawn up there (or forced) will be stopped by the filter.
    Jan 2009
    blankedy
    you could plum the inlet to the box straight to the fog light area (i.e. remove the fog light and cover with a mesh).
    i've removed my fog lights and replaced with mesh to improve the airflow over the SMIC (and done the pikey mod as well). you could plumb the airbox to the other side.
    Aug 2008
    Trim the standard intake bell to increase it's diameter to the size of the hose you have then plastic weld the 2 together.
    Cheers,
    John
    Mar 2008
    NSW
    Quote Originally Posted by JCM308 View Post
    that might sound like the go.....how would I plastic weld it together?
    thanks for all the help guys so far
    Jan 2009
    WEst Sydney
    I still say add the second duct from underneath. Its easy to return to stock if you dont like, just remove and block up the bottom of the airbox.
    No way rocks will fly up all that tubing.. Some people have pods exposed underneath the car.
    It would give the same if not a better airflow than the seat intake.
