Whats your engine code mate????? Some are as low as 650rpm but this was with the Magnetti marelli set up.
Engine code - look at your white sticker in your boot
Jmac
Would anyone know what the normal idle RPM should be for an automatic 2001 Polo? Mine idles at about 750-800 RPM when in traffic.
Jmac
Alba European
Engine code is AHW
Test rpm for that engine is 630 to 730 rpm, so i would say that is all good mate, its not cutting out is it????? if it is there is a couple of things you can do
Jmac
Alba European
A few times it stuttered as if it was going to cut out but it hasn't yet. Maybe a dirty throttle body.
Indeed , but the MAP sensor is prone to getting oily, clean it as well mate will do the world of good. Then readapt the throttle body with VAGcom or the likes
Jmac
Alba European
Thanks for the advice. I will look at cleaning the MAP sensor.
