ok thanks Gary. I'd read long ago of people having dramas when they couldn't properly bleed the systems, lots of the systems have pressure caps on them and also due to the possibility that the fluid temp could get up, so assumed that they had to be pressurised.
So what you are saying re E85 is that because you can run so much advance that combustion temps and EGT's run that much lower than petrol at a same relative (for the fuel) state of tune that you can see 10 degree cooler water temps. wow. E85 sounds like the way.
Thanks Redliner I'll check out those links. I reckon it's be pretty straightforward to run a water to air core where the stock one is Simon as you'd still have a shorter inlet tract than any other air to air setup and can save on $/effort designing pipework as its all there for you. For me If I do do it I'd really like to give it a shot using a passenger side feed inlet manifold for the shortest possible inlet tract. Just from a maintenance/servicability point of view having it all right there and accessible with the DV plumbing, sensor wiring right in front of you and the weight as far back as you can get it (not sure how low I can get it though) is attractive.
