Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: How to put your car on a diet
    Jan 2009
    sunshine coast
    Hi guys , got curious and asked around about removing seat. (yes mods before you delete this post i know its done before) however, i rang my insurer , qld transport and i currently have a few contacts with the police and they all seem to be happy. so today i removed my back seat and decided to weigh up some items.
    Back seat , including back rest and seat components : 32kg
    spare wheel (i have a 16' spare and i have 17' wheels hence redundant and hell what else is vw road assist for), jack , some upolstry : 20kg
    odessey 680 battery, and removal battery mounts and factory air box : 13kg
    + 2kg bmc cda (i think it might even be lighter)
    + 2kg custom battery mount made by your truly
    = total reduction of 61kg
    now all i need to do is lose 15kg and she'll really be a light weight
    so just in case you were wondering if all this back seat removal was worth it id say yes , hell you can do half this mod with no cost infringed at all.
    " I wait I resolution derive pleasure this " latest spammer post
    Dec 2006
    Gold Coast
    i have none of what you listed and i have even more stuff taken out. lol.
    Jan 2009
    blankedy
    Sounds good!
    Were you Mighty Mods inspired?
    Jan 2009
    but hows the road noise with out that back seat? I notice increased noise without the parcel tray and seats folded forward when I put bikes in, let alone removing the seat and it's sound absorbing ability.
    Mind you, that's huge weight reduction. How much do ferrari, porsche and lambo charge to lighten their beasts...
    Jul 2007
    Auckland, NZ
    having 17 inch wheels doesn't mean, 16 inch won't fit as spare...
    good weight saving! When I go track, I remove all head rests except for driver's, remove sparewheel + tools.
    How difficult is it to remove rear seats completely?
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
    Jan 2009
    sunshine coast
    isn't that difficult at all , floody gave me the heads up. the larger portion of the back rest you have to fiddle with a little bit at differant angles, but seriously this took less then 15 mins. there is a lil bit of extra noise but most of it is just seat harnesses etc.i also took out parcel shelf and the flooring that covers the spare, what else did you take out kai? , as crazy as this sounds i was even looking at recaros , and they do actually make a seat that fits our cars. so far i havnt taken her for a test run , but i might tomorrow, just for a bit of fun.
    funny enough i actually did all this before i watched the mighty mod vid , ironic i know.
    to remove the back seat, climb into the back and use the seat release to move the seats forward. on both sides near the exterior of the car you'll notice a gray little fastener that's keeping the seats from simply pulling out. get a flat tip screw driver and gently push them back towards the rear of the car, then pull the part of the seat out of its housing, once released manouver the back rest towards the side of the car to pull the other side of the hinge out of the centre holder. the whole back rest will come out. the other (larger side) , requires manipulating it in all sorts of angles and gently pulling towards the side of the car, to make life easyer unbolt the centre seat belt where it connects to the floor , you'll get there with a little patience. once there both removed you can simply remove the seat parts by unhinging where they attach to the floor.
    Very inserting topic! i see lots of people asking the same in others forum too... asking how to put your car on a diet... but anyone think of diet yourself first?
    just my 2 cents
    2013 4Motion "BLACK BEAR"
    http://blackbeartiguan.blogspot.hk//
    Jul 2007
    Auckland, NZ
    Not a bad point... I had a guy who owned a Starlet Turbo with huge amount of work gone on it... I think he weighed at least more than 120kg... what's the point.... little car and you weight at least more than 10% of the vehicle...
    Hmmm...
    Yes, empty your bladder and bowels before you go drags next time!
    Also never run your car with full tank
    Maybe even run coolant and minimal level + throw away the window washer bottle or at least empty it out.
    Hehehe.... just kidding.
    For me, I won a 5 door car, I don't mind the car seats fold on rear... just that brings up significant road noise... so I like to keep the seats up.
    Feb 2008
    ACT
    Have applied the diet theory to my Polo also.
    Certainly there is a lot more road & exhaust noise in the car without the interior trim, which is as you'd expect. You also get some quite noisy vibrations where plastic parts previously held fast by other bits of trim end up resonating at idle.
    For street driving I always keep a 17" spare with a socket wrench and jack - yes there's VW Assist but it takes less than 5 minutes to swap out a wheel so I'd rather not wait for someone to do that for me. Being a TT rim the back plate is too thick to install the toolkit that usually fits inside the spare wheel so the wrench and jack are secured behind the front seats.
    Jun 2009
    Caz'bah
    You could probably save yourself from alot of the rattles with some foam and electrical tape.
    The seatbelts would be a massive annoyance smacking against bare metal constantly so just wrapping and taping them would help immensely.
