Go the Disco Potato!
Seriously though, most discussions I've read about this turbo suggests that it needs a 2.0 litre engine as a minimum to spool decently for road use + you'd want to drop the compression to take advantage of the potential boost increase. Of course there is a stroker kit that takes care of both of these concerns... 1.8t 20v 2.0L Stroker Kit (06a)
Resident grumpy old fart
