Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 53
Thread: How fat can i go...
  1. #41
    Jan 2008
    Cremorne, Melbourne
    Quote Originally Posted by mozzzy_2000 View Post
    So how much spare room is there on the inside of the stock rim to play with before it scrubs the shocks? I think mine are ET43. So these wheels add 24mm and there's still enough room not to rub the shocks?
    on the inside, using the offset calculator, it says the fronts will have 12mm MORE clearance and the rears will have 2mm LESS. I'm pretty confident that 2mm less clearance will not cause scrubbing.
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
  2. #42
    Nov 2008
    Wembley, WA
    Quote Originally Posted by [-Polo GTI-] View Post
    Are you using spacers on the front? Cuz when I plug in the numbers for the front wheel it says it gives you 5mm more on the inside and extends 32mm on the outside which is a fair bit. That may scrub on the wheel arches on full lock. Should look pretty wicked 'n fat thats for sure!
  3. #43
    Jan 2008
    Cremorne, Melbourne
    what offset are you using for standard in the calculation? i have a late '06 model which has an offset of +43....give it another go.
  4. #44
    Nov 2008
    Wembley, WA
    Post
    Well going with the figures from your post on pg 4; stock is 6.5" and ET43right? And you said you had 7.5" and with 25ET. According to that it says it gives you 5mm more inside space and extends 32mm on the outside. Not having a go at you, just interested in the calculation thats all.
    The rears I got the same figures as you though.
  5. #45
    Jan 2008
    Cremorne, Melbourne
    nah i know you are not having a go. i thought the stocko rims were 7" wide, thats what i've been running my calcs off
    when i get them on i'll see if there is any scrubbing. i'm hoping not.
    keep in mind the tyres will be stretched.
  6. #46
    Nov 2008
    Wembley, WA
    yeah the stock rims a weeny 6.5" wide. Thats why if you look at the 205's on them you can actually see they can be stretched at least another 5mm on either side because they sorta have a lip of unused rubber. That's why 7" is the minimum recommend rim for a 205, 7.5" is probably ideal and 8" is a little stretched although still very much doable. 9" inch is doable but looks a little odd if you ask me.
  7. #47
    Jan 2008
    Cremorne, Melbourne
    I've got aftermarket 17x7's on so I've never really looked into the specs of the stocko's, I bought the car with the wheels it currently has on it.
  8. #48
    Nov 2008
    Wembley, WA
    ah well there you go then!
  9. #49
    Jul 2007
    Auckland, NZ
    I have recently replaced the wheels with RS4 replicas. 17 x 7.5 with 205/40/17. It's ET 38. Look spot on in terms of width. I was comtemplating with ET 35, but really happy with ET38.
    Will try to post up photos
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
  10. #50
    Nov 2008
    Wembley, WA
    Just a query; what is "staggered fitment" in regards to the type of wheel?
