Again, total agreement with Stuwey - putting the semis on the front and leaving the street tyres on the rear will turn you around as soon as you think about lifting off mid turn. I once scrubbed in a single A048R on a rear rim and it TOTALLY screwed the handling of the PoD, making the car understeer in a diabolical way and turning in very strangely as the car would seem pivot about that tyre - it was weird enough that a Polo GTi driver following me on that cruise commented on how odd the car looked in the turns.
Originally Posted by
sambb
But they let go very suddenly in the wet and don't tell you they are about to in the way that the street tyres had thats for sure. Its just a question of keep them on and hope it doesn't rain or get the RE003's on and hope it will!
This!
sambb
If I do get the RE003's put on whats the quickest way to scrub off the greasy new top layer. Will a quick flog on a favourite stretch have them ready?
Street tyres (any tyres really, except GP 125 slicks) seem to scrub in almost immediately IME once you lean on them a bit so about 4 corners into a decent fang on a dry road should do it, I would think.
Resident grumpy old fart
