Originally Posted by
sambb
As long as its steady I'd have thought you'd be ok. At night if you have the stereo going and headlights on it can load the engine which will affect the idle. Then during the day you may have had the AC on switching in and out. The only real way to tell is have everything turned off and the car warm and see then if you get a variation. My idle rpm was always consistent but it'd get big dips and hiccups. This turned out to be the SAI system which I'm pretty sure may still gets signalled to run even if the car isn't at cold start. Since I did the delete It hasn't happened once.
