WHat about air/fuel ratio?
ECU will compensate. When you switch the engine "off" your possibly driping injectors will waste you fuel even when you don't drive. Air/fuel ratio alone means nothing if you don't check exhaust gases with 5 gas analyser. ECU light on the dashboard will not come "on" untill it is realy bad!
So proper diagnosis before replacing any sensor will save you $$$ and time.
