Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: High Fuel Consumption... whats wrong?
    Adelaide hills, SA
    Quote Originally Posted by GoLfMan View Post
    105,000km's
    Did you try to put injector cleaner in the tank?
    I use - Interject injector cleaner.
    If the injector cleaner doesn't help had it properly diagnosed, changing sensors and quesing will only cost you more at the end.
    Sep 2006
    Australia?
    WHat about air/fuel ratio?
    Adelaide hills, SA
    Quote Originally Posted by Mk3vr6 View Post
    ECU will compensate. When you switch the engine "off" your possibly driping injectors will waste you fuel even when you don't drive. Air/fuel ratio alone means nothing if you don't check exhaust gases with 5 gas analyser. ECU light on the dashboard will not come "on" untill it is realy bad!
    So proper diagnosis before replacing any sensor will save you $$$ and time.
    yuuuuup definately would... but my 8v in my golf will be getting a welcome boost of performance
    Matt sold you my old autotech cam?
