Results 1 to 9 of 9
Thread: Help with Ultra racing brace clearance question
    Nov 2012
    Guys, anyone got one of these with the original airbox in place?
    Melbourne, Vic
    I have one, fits over the box with enough clearance, however you will need to remove the brace to get into the air-box..
    2016 Golf R, APR Stage 1
    2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
    Did you notice much of a difference once fitted?
    Cheap, Fast, Reliable. Choose two.
    Melbourne, Vic
    To be honest not really, the most I noticed was it helped balance out the UR rear sway bar, made turn in a bit sharper, the swaybar actually introduced a little more understeer in cornering
    Nov 2012
    Mate any chance you could post a photo of the clearance between the underside of the bar and top of the airbox with a ruler? Here's mine,
    I'm trying to figure out if I can get the ultra racing brace over my airbox...
    Melbourne, Vic
    Judging by that pic it will be a tight fit, maybe by a few mill if your lucky, will grab you the measurements in the next day or so
    I can only just fit my finger between the box and the bar
    How are you finding the custom airbox?
    Nov 2012
    It fits! That's the important thing. The photo is misleading, it's shorter than the stock one by about 5 mm but taller by the same amount just where the snorkel turns through lid of the box. Hoping it'll fit, just depends on where the bar crosses the top of the box. If you could post up a top down photo square to the box lid it'd help a heap too.
    Sent from my GT-I9505 using Tapatalk
    Melbourne, Vic
    Sorry took so long, the weather here is pretty crap at the moment, this should help
    Nov 2012
    Thanks heaps mate.
