Daily: 2010 VW Jetta Highline
** All information I provide is probably incorrect until validated by someone else **![]()
I'd ballsed up when putting the hydraulic tensioner on and released the bloody pin from it. I don't have a bench vice, though my tensioner seems to have quite a bit of low resistance / free play at full extension. The old, removed one is rocket solid, the new one can be compressed about 1/3 with my finger. Just checking with a few "in the know" to see if I've stuffed the tensioner, or it's faulty, or if it's safe to install.
Buggered my sunday as I had a few hours without the family to get it back together and did this...
Releasing the clamp was my fault. It was putting load the hydraulic tensioner piston against the hydraulic roller when trying to install as I didn't have a spare hand to hold the roller bit up whilst trying to get the top screw in.
So I need to validate the tensioner isn't stuffed, than compress somehow, and try again.
If you can push the pin back in with finger pressure then I'd say its cactus. I had one that was fully extended accidentally and I squeezed it back in bit by bit with a vice before re-pinning it. Never could have done that with finger pressure unless you are some kind of mutant rock climber. Not sure what your time line is but I have one right here brand new that I can send you. Its an NTN. I'll post it to you tomorrow if you want cos I wouldn't trust yours.
