Results 1 to 10 of 11
Thread: Help - rear brake lights not working!
    Mar 2008
    NSW
    Hi all
    wondering if I could get some help / suggestions on what to do here.....basically realised both brake lights at the back are not functioning...the thin strip in the middle still lights up though...but im not getting any light errors on the dashboard
    This happen to anyone before?
    Thanks in advance!
    Feb 2008
    Both bulbs may have blown... It's rare to happen at the same time, but check them out anyway.
    Mar 2008
    NSW
    hmm thanks ill take a look...i do remember one stopped working before the other so definately didnt happen at same time..
    Brake light switch?
    Cheap, Fast, Reliable. Choose two.
    Feb 2008
    Quote Originally Posted by Stuwey View Post
    Brake light switch?
    Nah, cos he is still getting the center break light.
    Jan 2009
    blankedy
    Checked fuses?
    Feb 2008
    Checked fuses?
    Fuses most likely won't be an issue as the center light is on the same circuit, and this is still working.
    Quote Originally Posted by Blitzen View Post
    Yup, I really should read the whole question.
    I'm going with two blown globes. Simple job!
    Mar 2008
    NSW
    lol sorry guys any idea how i remove the tail lights to check the bulbs?
    thanks!
    Feb 2008
    I think ig you pull the carpet out of the boot area behind the light, you will see the mounting golds or screws for the rear tail lights... Once you have pulled them out, then you can access the bulbs.
    EDIT!!!
    I was wrong with the above advice... The whole light assembly just pulls out from the body.
