Results 1 to 10 of 19
Thread: Help! My ESP light stay on...
    Hi folks, when I'm driving today the ESP light suddenly stay on and I cannot swith it off by pressing the button I tried to switch off the engine and on but it still stay on do u know what the problem is?
    By the way I just changed the battery today and now running on a different size of spare tyre..
    What is the problem there? Is it the tyre or the battery?
    Thank you folks!!
    Kelvin
    2013 4Motion "BLACK BEAR"
    http://blackbeartiguan.blogspot.hk//
    Alfred Cove, WA
    .... not meaning to take the piss.... but you sure its the the tyre pressure indicator?
    If you change wheels it will set that off.
    Quote Originally Posted by Kai View Post
    And then dont forget the most important mod for gays.
    Blow off valve - 300
    Its not the tyre pressure indicator, is the ESP light indicator, it switch on by itself... But then when i drive it back home today, it back to naomal.... dunno why?!
    Jan 2008
    Quote Originally Posted by kelvniii View Post
    That happened to mine when it was on the dyno once. I'm told the ESP light is on until is learns what having traction is like. So after the battery came out it was reset and had to learn again. Takes a few kms.
    Jul 2007
    Gold Coast
    it might be a good thing!?
    Jan 2008
    Cremorne, Melbourne
    are you sure it's the ESP or is it the EPC light. my EPC light came on once and it was just my brake light was out...had a faulty brake light switch (common problem apparently).
    if it is the ESP light, this happened to someone else recently, they found out that they didn't switch between APR programs properly and the system was struggling to register what was going on. he just had to redo the program switch procedure properly and it was sorted.
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
    Quote Originally Posted by VW GTI View Post
    yes i guess you are right! the traction is different
    cuz i'm now running a different size of spare tyre...
    and it takes a few KMs to let her learn again!
    Aug 2008
    This happened to mine on Saturday night and yesterday. I've changed my brake lights on Sat morning (both are working fine). I don't have a tune. Can anyone help?
    Cheers,
    John
