When you say dome light do you mean the central light that comes on when you open the doors, that also contains the individual map lights? If so you should be able to pop the whole plastic part out quite easily, it's in two sections. The front section (under the 'grill') hosts the alarm sensors so you can leave that there, the remainder clicks into a cable so when you pop it out you can disconnect that cable to work on it.
Are you just wanting to change one of the bulbs? They screw out from the top side from memory....
MY10 Golf 118tsi DSG | MY07 Polo GTI
