Results 1 to 8 of 8
Thread: Headlight low/main beam problem
    Mar 2011
    Camden, NSW
    Hi Guru's,
    I've got a problem with my main beam (some call low beam) headlights where they have begun to take a random time to turn on.
    It used to be a couple of seconds delay, then about 10, 20, 30 seconds, now they can take much longer.
    I haven't done any physical inspections yet (just tried searching forums), but has anyone seen this type of behavior before?
    If it was a fuse I thought it would just stop working all together, if it was the bulbs I wasn't expecting them to both be misbehaving.
    I have a 2006 Polo GTI 9N
    Thanks in advance!
    Mar 2011
    Camden, NSW
    My electrician mate reckons it's likely a relay.
    Anyone know where I can get a Polo GTI parts list or electrical wiring schematic?
    Melbourne, Vic
    Your not running a HID kit are you?
    Standard Halogen is instant, but HID can have a delay and also takes time to "warm up"
    Oct 2009
    Canberra ACT
    Both my low beam globes went out together
    I just replaced them and they've been sweet ever since
    06 VW 9N3 Polo GTI - Reflex Silver Leather/OEM Colour coded S/guard/OEM Lower Honeycombe Grille/NSP Boost Gauge/APR Stage 1+,Dogbone & DP/K&N filter/Forge s/shift,DV008 & Strut brace/PD 160/Samco camo TIP/Whitline RSB/FK AK's/17 x 8 Oettiger RE's/Alpine Head Unit & Sony Amp. OEM+FTW
    Mar 2011
    Camden, NSW
    Just dropped into see Matt at Camden GTI Campbelltown - he fixed it on the spot!
    Turned out I had a faulty switch, Matt was able to plug in a spare he had and it fixed it straight away. Must've been a faulty relay.
    Brand new switch from VW was around $200, Matt fitted a spare he had for less than half that - thanks!!
    Mar 2011
    Camden, NSW
    Quote Originally Posted by flat6 View Post
    Nope - just running stock - thanks for the suggestion though!
    Mar 2011
    Camden, NSW
    Quote Originally Posted by Smead View Post
    Amazing how they can both go out within such a close time of each other
    Jan 2009
    blankedy
    Awesome outcome, Matt is the man...
