Page 16 of 24 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 236
Thread: has anyone upgraded their stereos?
  1. #151
    Mar 2009
    Quote Originally Posted by diarx View Post
    sweet, thanks
    Also ralfi, in regards to with removing the stock stereo with keys, be careful the way you go about it - I ended up forcing the keys too much on my first try and damaged one of the metal tabs on the inside.. I only pulled the stock unit out to check the wiring out then pushed it back in again, but when it came time to installing the new unit it was near impossible to get the stock one back out. I struggled for a total of about 6 hours trying to get it out again!
    Definitely get four keys, and make sure they're the right ones - I think mine may have been slightly different than the ones you're meant to use.
    Thanks. Yeah I ended up driving to my nearest Ultratune & used two of their keys to easily remove the thing.........so silly only supplying 2 of them with xcarlink....
    Anyway, got it all installed & working - velcro with tape on the back came in handy to mount the box & velcro ties were used to store all the cabling. I like how the microphone came with a clip, so I just clipped it onto the cable just near the bluetooth module itself in a pretty convenient spot.
    Though I notice some slight interference when wirelessly streaming music via bluetooth (mostly at higher volumes), but when direct connecting the iphone, it sounds much clearer & louder (distortion-free). Is this normal when streaming via bluetooth?
    MY16 MK7 Golf GTI
    - Manual - Sunroof - Folding Mirrors - Lock/Unlock Chirp - 4x Indicator Flash - Traffic - MK7.5 LED Tail Lights with Sweeping Indicators - Dynablink Sweeping mirror LEDs - White LED's on rear rego plate -
  2. #152
    May 2011
    CAMPBELLTOWN
    can i have some links to some decent headunits
    if any has any good ones
  3. #153
    Sep 2006
    Quote Originally Posted by FLYINGTI View Post
    Good ones, how much do you want to spend? Single or Double Din ?
    Do you want GPS, DVD, Bluetooth ?
  4. #154
    May 2011
    CAMPBELLTOWN
    Quote Originally Posted by vwthunder View Post
    i would like a double din,gps isnt important but would like a touch screen style
  5. #155
    Feb 2007
    Brisvegas
    Does anyone know where I can pick up a single din pocket for the Polo?
    Cheers.
  6. #156
    Jan 2009
    blankedy
    Need to get an aerial adaptor, makes sense to get a loom adaptor as well...
    Does this look right?
    From here: euroadapterset2 | eBay
  7. #157
    Jun 2007
    Just wondering, have anyone installed their amp/crossover from their upgraded sound system underneath the passenger's seat?
    At the moment, mine is situated in the boot and it is taking up considerable amount of volume as I've build a false floor to accommodate the units. But I now want to move them all to the front, and retrieve my space again.
  8. #158
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by VWindahouse View Post
    I used a generic Aerpro but it needed a lot of mucking about to make it fit well and the colour doesn't quite match the console (it DOES match the colour of the original RCD-210).
    To source a pocket from VW will cost you about $85 or else you can check the wreckers for a 9N Polo as those came with the single DIN unit and a pocket below
  9. #159
    Mar 2007
    Gold Coast
    Quote Originally Posted by Adam View Post
    I think theres an air vent tube there and the under seat tray would limit space.. Let me know if you get it to fit
  10. #160
    Feb 2007
    Brisvegas
    Quote Originally Posted by kaanage View Post
    Thanks mate, grabbed a VW one from Jmac!
Similar Threads
  1. upgraded fuse box? any idears
    By finemk1 in forum Mk1 Golf
    Last Post: 14-08-2006, 10:26 PM
