Page 5 of 24 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 236
Thread: has anyone upgraded their stereos?
  1. #41
    Mar 2007
    Melbourne, Vic
    By the looks of it that adapter doesn't have a CANBUS adapter so you'll have to get switching power and illumination from elsewhere (ie: the cigarette lighter socket). It still saves a lot of hassle though as you'll only have to splice for those two things and not have to worry about all of the speaker wires.
  2. #42
    Jun 2007
    Would someone be able to explain what these following means?
    SAFE:
    +UB:
    CAN/L
    CAN/H
    Edit:
    Ok. Sorry to be a pain. but while i am searching for what the upper word means... the link below say the 9N3 polo doesn't use CAN-BUS?
    http://forums.vwvortex.com/zerothread?id=2465335
    And. i don't have any seperate connectors to the car, other than the 2x 8 pins plug...
    I am confused now
  3. #43
    Aug 2006
    Skye, Victoria
    Blaupunkt/Bosch make a canbus adaptor loom that makes it plug and play. not cheap thou.
  4. #44
    Mar 2007
    Melbourne, Vic
    Quote Originally Posted by Adam View Post
    SAFE:
    +UB:
    CAN/L
    CAN/H
    Edit:
    I am confused now
    As far as I could tell SAFE and +UB both seemed to be permanent power. I think when I did mine my mate hooked up the permanent power to SAFE. There may be a difference but not one we could tell with a multimeter.
    CAN/L and CAN/H are the CANBUS connections. You won't be able to use them for anything with the harness you have. This is where the power on/off, illumination, speed etc signals come down. You'll have to either use a canbus adapter as mentioned above which will generate the signals on separate wires for you, or find another source for it (ie: the cigarette lighter socket as i mentioned before)
  5. #45
    Mar 2007
    Melbourne, Vic
    I'm going to post the reply I sent to your PM a while back so that so that other people can read it or add to it. Some of the things you've asked about i've mentioned in the message.
    Hi Adam,
    The only extra thing I needed to buy was an adapter for the aerial. I wasn't able to find one in a shop but my mate who is an auto elec sourced it for me. I think this is the one...
    http://www.aerpro.com.au/list.php?pc...n o=&cat_sno=
    It's a VW/BMW to Japanese aerial adapter.
    The only other thing i bought was a single din pocket to go underneath and some masonite to make up a support for the head unit when sitting in the top din.
    I don't know if you need the following info or not. I tend to ramble so forgive the length.
    One of the difficulties with the Polo is that it uses CAN BUS for everything instead of individual wires for each function which is why it's hard to get a wiring harness. Fortunately there are ways around it.
    My auto electrician friend helped me do the install so he was able to think of a trick that i hadn't considered.
    The way he does his installs is to splice into the existing loom rather than cutting the original plug off. That way if you ever need to replace the stock head unit you don't have to rewire the original plug. You'll have to do this for permanent positive, negative and all your speaker wires. The stock head unit has a wiring diagram sticker on it though which takes the guess work out of it.
    There are two positives listed. One is marked as SAFE and i can't remember what the other is marked but from what I could tell with the multimeter they are always permanent positive so using either for that should be fine. You'll have to use the negative from the wiring harness as well as there isn't any metal to screw into close by in the dash.
    Because of the CAN BUS there is no accessories or illumination switching wires in the harness (there is CAN H and CAN L, one of which looks like it might be switched with the ignition but isn't so don't try and use them). You can get these from the cigarette lighter/aux power socket though. There are screws in under the rubber mat in front of the ash tray that you have to unscrew and you have to unclip the plastic cub holder area from around the handbrake lever which should allow you to pull up the plastic from around the ashtray to get into the ciggy lighter.
    Unfortunately doing it like this you lose the feature that keeps the radio going after you turn the car off until you open the door. The only way around this is to spend probably $100 on a wiring harness adapter from the UK that includes an accessories wire that is generated from the CAN BUS signal.
    If you find this info useful it might be an idea to post it in the headunit removal thread so that other people can find it. I'll leave that up to you.
    If you have any questions send me a pm.
    Ben.
  6. #46
    Jun 2007
    Quote Originally Posted by morbo2000 View Post
    coolies! yeh sorry. i re-read your pm and realised half the stuff was answered already!. =(...
    Something i found out, and not with full certainty is that "SAFE" is a constant +12V, and UB+ is switch?????
  7. #47
    Jun 2007
    Got the car back from warranty service....Got everything hoooked up....Heres a trail run for the headunit. One problem so far is that the headunit doesn't turn off when the key is out. :S ? maybe its that one hour thing. so will have to investigate more!
  8. #48
    Mar 2007
    Melbourne, Vic
    [IMG]http://img160.imageshack.us/img160/8690/p1
    That's why my mate and I didn't think there was any switching voltage directly in the loom. +UB definately didn't seem switched to us. That's why he used the cigarette lighter socket to get switching power as it is switched with the ignition.
  9. #49
    Jun 2007
    I thought about that right. But doesn't the ciga lighter socket remains on after the key is out as well? cuz mine can still charges things when key is out?
  10. #50
    Mar 2007
    Melbourne, Vic
    Hmmm, mine doesn't. Well actually I haven't tried but I know the stereo turns off and that's definately where we got switching power and illumination
Similar Threads
  1. upgraded fuse box? any idears
    By finemk1 in forum Mk1 Golf
    Last Post: 14-08-2006, 10:26 PM
