Page 3 of 24 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 236
Thread: has anyone upgraded their stereos?
  1. #21
    Oct 2006
    Finally had the sub put in last saturday. Pretty happy with the setup already. The splits are still the stockies. They do a good job I must say. Might not even change them. Sounds fine. Changing the head unit and having it tuned made a big difference.
    Revotechnik stage 1 flash, BC Sports coilovers, Lenso Type M's, APR R1 diverter valve
  2. #22
    Feb 2007
    bright town VIC
    So just confirming...are speakers 6 1/2 inch or 6 inch front and rear....??
  3. #23
    mdonohoe Guest
    FYI - If your changing head unit I can provide pin-outs for the speakers.
    Also, if you place your new head unit in the bottom DIN and use a $20.00 "Clip In DIN" from Supercheap(easily available) it will fit perfectly if you use Double Sided tape to "chock" up the back.
    Cheap way to do it Looks factory.
    Thanks
    Matt
  4. #24
    Nov 2006
    Pics please
  5. #25
    mdonohoe Guest
    Sub or my install?
  6. #26
    Aug 2006
    i amp both front and rear stock speakers.. turned out prety nice, crisp sound and added a sub for bass..
  7. #27
    Mar 2007
    Melbourne, Vic
    How do you remove the stock HU?
    How do you remove the stock head unit? I've read references to VW removal tools that slot into the 4 holes in the HU.
    If you don't have to pull the dash apart to replace the HU how do you mount the new one in (considering it's a double-din hole and i have a single-din replacement to put in)? Are there mounting holes to screw into or do you use use the mounting bracket that comes with the new headunit (I have a Pioneer 5850MP with an iPod kit to put in). I want to put the HU in the top with the supercheap pocket (mentioned above) put in the bottom (only because i think it would look weird to me being the other way around as HU to top was how it was in my Magna).
    mdonohoe would can I please get the speaker pin-outs from you? Thanks.
    Are there any other electrical issues I need to be aware of when putting the new HU in? I've seen references to CAN-BUS wiring but i'm not sure if that applies to the polo. I grabbed a male ISO socket to bare wires adapter so I wouldn't have to solder into the factory wiring (hopefully male is the right one, i haven't pulled the stock hu out yet so i'm not sure if i have the right adapter).
    Where do you run your power through the firewall for a sub?
    Sorry for the long post, i'm a bit of a rambler.
  8. #28
    Feb 2007
    bright town VIC
    I put in a Clarion DXZ466MP single DIN and left the standard speakers on the advice of the stereo shop (Autobarn). Cost me $400 installed, of which $50 was the special VW antenna adapter. Sounds much much better than the standard unit but not as good as it did in the shop, and probably should have spent a little more. So hard to tell when one stereo shop says once you get two up from the base model all the units have the same sound quality and another guy says they are all different.
    Apparently the most popular deck on the market is the Kenwood version with built in intertia meter to read 0-100km times Roughly $600.
    May do the speakers but to improve on standard is about $300/pair, plus another couple of hundred to fit with sound deadening.
  9. #29
    Sep 2006
    Brisvegas
    cant stand kenwood personally. Clarion is much better imho.
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
  10. #30
    I've got an amp and 10inch sub from an old car, is it possible to hook this up to the factory head unit?
Similar Threads
  1. upgraded fuse box? any idears
    By finemk1 in forum Mk1 Golf
    Last Post: 14-08-2006, 10:26 PM
