**** really? never had the unit crash on us. I don't think you can go in with high expectations of the general interface of the unit functioning like a Japanese branded head unit for the price. What actually happens when the unit crashes? does the screen go blank, does it hang?
usb works for me, but I guess like most of these old CE based devices you're limited to fat16/32 filesystem and 8gb max
I wonder if any changes in the canbus between year models could have anything do to with the issues you're having? My missus is running an '08 model and after I had the accessory switch wired in by a pro it switched on and off with the key flawlessly.
btw, if by crashing you mean it's cutting out after a certain time limit after being switched on (I think its 10 minutes) it could be that it isn't wired up to your cars ignition/accessory power properly. It won't operate correctly if you've just plugged it in via the canbus connector. Given you've said it won't turn back on unless you restart the car and won't turn off with the ignition (which are the same problems I had til I took it to an installer) I'd say you might have to double check your wiring.
