Page 11 of 24 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 236
Thread: has anyone upgraded their stereos?
  1. #101
    Dec 2010
    Perth
    If he drilled out the original speaker pod rivets, maybe the old rivets are in the bottom of the door?
    1997 Lotus Elise S1
    Fiesta
    2012 Triumph Tiger 800 XC
  2. #102
    Sep 2008
    Hmm...maybe...I'll have to get him to check. But surely a small pieces left of riveting wouldn't be causing such a massive rattle rite? One thing I did notice today was after parking outside most of the day in hot sunny weather, it how has reduced some of the rattling whilst driving but you can still hear it when you slam the doors to close them. Ideas anyone?
  3. #103
    Nov 2010
    I've just picked up these off ebay.
    http://cgi.ebay.com.au/Kenwood-CD-St...item5195753e11
    http://cgi.ebay.com.au/VOLKSWAGEN-Po...item5195754b84
    I'll remove the CanBus pins which won't be getting required, use the new HU's built in amp to drive the rears and a separate amp for the fronts.
    By the way, I don't know if anyone has ever shopped at the Pioneer online clearance shop, but it's worth a look.
    I picked up a 2 x 70 RMS amp for only $70 (freight is free!) and it was delivered within 2 days!
    https://shop.pioneer.com.au/itf/phx/phoenix.nsf/Index
  4. #104
    Adelaide hills, SA
    I can't see anything, the ebay links are expired.
  5. #105
    Nov 2010
    I've just refreshed the links with whats remaining at the ebay store as opposed to the one's that I purchased.
    Other branded ISO adapters are also available. (Clarion, Alpine, Pioneer etc...)
  6. #106
    Nov 2010
    Also have the part number for an OEM single DIN radio pocket that comes in the Polo Match 9N.
    6Q0857058C1QB
    Retail is $78 from VW.
  7. #107
    Oct 2010
    Melbourne, VIC
    Did you get the fakra=>DIN antenna adapter?
    You only need the amplified version if you are interested in maintaining AM reception. FM works fine with a straight physical adapter.
    A few of us here have used the generic Aerpro pocket rather than the VW one as it only costs $20. But it does need a bit of modding to fit and doesn't colour match the console plastic, exactly (it does colour match the OE RCD200 head unit!)
  8. #108
    Nov 2010
    I didn't get the amplified version, just the straight physical adapter.
    I'm sure I'll be told the first time my wife drives to work and tries to listen to 2GB for the traffic report....
    And regarding the OEM pocket, there is a second part number that goes with it.
    As usual, VW have a rubber mat (Retail is $22.00) that sits inside the pocket to prevent things sliding around which has its own part number:
    6Q0858167A9B9
  9. #109
    Hi guys,
    Just wondering if anyone has had experience with installing the Eonon d5101 in a 9n3 polo gti?
    ie. this unit: Eonon D5101 | Car DVD | Specific Car DVD | Car DVD for Glof/POLO
    Ran into a bit of difficulty having it turn off and on with the ignition - seems to only turn on manually with the power button.
    I'm a little confused as I was led to believe the included harness made it plug and play and didn't need any wiring into accessory power?
    (for the record, I'm very newb with stereo installations, did one of these specific fit Eonon stereos on my Astra and it was pretty much no issues/plug and play)
  10. #110
    Dec 2010
    Perth
    Quote Originally Posted by injidup View Post
    Here are two pics that should help:
    And a BlurryCam special of my not-so-professional connection with a cannibalised ISO connector:
    These wires have been tidied up now!
    Hope they're clear enough!
    Total cost (not including the head unit): Under $50 (Removal keys for RCD200, ISO Adapter, Fakra antenna adapter)
    Since disconnecting the power from the battery when fitting the subwoofer, I no longer have power when the key is in the ignition.
    Does anyone know if this needs to be reset somehow?
    No volts at the pin shown as "Switched" in my pic.
    1997 Lotus Elise S1
    Fiesta
Similar Threads
  1. upgraded fuse box? any idears
    By finemk1 in forum Mk1 Golf
    Last Post: 14-08-2006, 10:26 PM
