![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
spraycanmansam
Has anyone pursued water to air intercoolers here? It would be easy enough to mount a small radiator in the front with the core taking up the original SMIC space. I'm going to make some cardboard cutouts of some cores and trial fit a few different designs.
Yeah, I did some preliminary investigations as I liked the idea of shorter air piping for less lag plus the temps should be more stable as jasn78 stated (if not as ultimately cool in ideal circumstances).
The main issues were
- Where does the air/water heat exchanger go (as noone asked)
- It needs a water pump with the proper flow rate and all the associated switching/wiring
- There's enough weight over the front end without hanging more water out there
Resident grumpy old fart
