Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 52
Thread: Has anyone fitted a bigger Side Mount Intercooler (SMIC)?
  1. #41
    Sep 2006
    The Treadstone name has become synonymous with quality intercoolers over the past few years, and we pride our selves on it! We manufacture our bar and plate cores with strict guidelines, and are specifically designed to maximize cooling using the most surface area possible in any given space. Our cores give the perfect balance between heat exchanging efficiency and flow. Our internal fin structure design is top notch, and is where the most important changes can be made to enhance the cooling rate. Treadstone intercooler cores feature a high heat-dissipating "Inner fin" design. This is ideal for medium to high boost levels on higher horsepower or upgraded turbo engines. The larger internal surface area provides superior cooling efficiency for radiating excessive heat and minimizing heat soak. In general, these design characteristics is what gives Treadstone Intercoolers the leading edge in intercooler technology
    MODS- TOO MANY
  2. #42
    Has anyone pursued water to air intercoolers here? It would be easy enough to mount a small radiator in the front with the core taking up the original SMIC space. I'm going to make some cardboard cutouts of some cores and trial fit a few different designs.
  3. #43
    Oct 2009
    Canberra ACT
    I have thought about it. There's a SEAT Ibiza here in Canberra with an engine swap to a Polo GTI engine running it. Beauty of water to air is you can mount the cooler anywhere. The kit costs roughly $300
    06 VW 9N3 Polo GTI - Reflex Silver Leather/OEM Colour coded S/guard/OEM Lower Honeycombe Grille/NSP Boost Gauge/APR Stage 1+,Dogbone & DP/K&N filter/Forge s/shift,DV008 & Strut brace/PD 160/Samco camo TIP/Whitline RSB/FK AK's/17 x 8 Oettiger RE's/Alpine Head Unit & Sony Amp. OEM+FTW
  4. #44
    Dec 2006
    Snead the other and the major positive for water to air is shorter piping and more consistent temperatures as water is less heat conducive than air
    Quote Originally Posted by seangti View Post
    The price of the car rarely indicates driver ability/lap time.
  5. #45
    Jan 2009
    blankedy
    Where would you put it on the Polo? Not much space
  6. #46
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by spraycanmansam View Post
    Yeah, I did some preliminary investigations as I liked the idea of shorter air piping for less lag plus the temps should be more stable as jasn78 stated (if not as ultimately cool in ideal circumstances).
    The main issues were
    1. Where does the air/water heat exchanger go (as noone asked)
    2. It needs a water pump with the proper flow rate and all the associated switching/wiring
    3. There's enough weight over the front end without hanging more water out there
    Resident grumpy old fart
  7. #47
    From what I can see the only difficult part is sorting out a core that will fit.
    1. The heat exchanger will easily fit where a front mount should.
    2. Water pump should be easy enough, switched to ignition.
    3. With the larger cores and heat exchangers I think this would be a valid concern, but with a smaller setup on our cars I don't think you'd even tell. Maybe, possibly, on the track.
    If I can mock up a core that will fit I'll post my findings.
  8. #48
    Nov 2007
    Post #9, 2nd pic is of my exact FMIC. Its actually a pic I took, lol.
    I have no noticable lag, excellent power retention (48 degree intake air temp on a hot day after 3 dyno runs) and all logs show boost is exactly what is requested, so no losses there either. The piping is maybe 5cm longer than before .....
    I'm not selling these (well not atm) either, so no interest there for me, merely stating a good FMIC is worth its weight in gold and without all the headaches (and costs) caused by upgrading the SMIC.
    and BTW, I picked up 7kw atw after fitting this FMIC, so its not just keeping power, but being better flowing adding power!
    EDIT: My core is also more than 150% bigger than the SMIC.
  9. #49
    Jan 2009
    blankedy
    Was that the frozen something brand / make?
  10. #50
    Oct 2010
    Melbourne, VIC
    Sharkie's is air/air
    Frozenboost is air/water(/air)
    What you refer to as the core is what I was thinking as the air/water heat exchanger (and what you were referring to as the heat exchanger, I had tagged in my mind as the intercooling radiator)
