I think a great solution lies in using the forge kit with a different core (assuming the core is as bad as people say).
The forge kit would be cheap to ship, probably fairly cheap from Forge if you organised a group buy and get better cores made up locally. I tried to get enough interest in replacement cores a while back, maybe more enthusiasm now? Sorry, this isnt really OT.
I think the Joey mod (wheel arch ventiation) is a great idea, once you take that lining out you see how little ventilation the cooler and the engine as a whole has. If there were more options for opening up the engine bay, it would be good to get as much airflow through, regardless of the cooler type. I did this before I got the front mount.
You're going to be somewhat limited in how much flow you are going to get through the lower side grills, Maybe remove the fog lights to help as much flow as possible, there are probably more side grill options that don't incorporate fogs.
Love the idea, always good to see an innovative idea pushed.
I'm pretty sure its not the core thats the main problem, its the "U" shaped design & poor end tanks that cause most of the problems.
