Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 52
Thread: Has anyone fitted a bigger Side Mount Intercooler (SMIC)?
    Jun 2008
    Ringwood, Victoria
    Yep, spot on Greg. We have performed testing on heat affected vehicles at work an it's not about the air you can get in, it's the expulsion of the heated air. You can have the best flowing front bar complete with sealed ducting but it won't do squat other than form an air dam if it can't escape.
    The other thing to consider is velocity drop of the charge air with a bigger cooler. Bigger doesn't always mean better...
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by Blitzen View Post
    I was looking at getting the Chinese version I found on EBay for about $230 landed, that way if it doesn't work out, it's no real biggy.
    This one?
    Resident grumpy old fart
    Point Cook, Vic
    Quote Originally Posted by kaanage View Post
    Really interested in this thread as I hate the idea of extra lag being introduced by the extra plumbing needed for most FMICs.
    But isn't airflow OUT of the rear area one of the big issues with the SMIC?
    Yep that is one of the challenges but surely it would be possible to address.
    FOLLOW US ON FACEBOOK
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by gavs View Post
    That's the big beef with the Forge it seems - you get lower heat soak but a bigger pressure drop according to some (not according to others, though )
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
    Oct 2010
    Melbourne, VIC
    Yeah, I know about that but even with screens, I'm worried about the IC core being damaged by stuff thrown up in the guards.
    Feb 2008
    That's the one, and if you look at the pics for the Godspeed, Goodspeed, and a couple of others, they use that exact same pic in their ad's...
    Point Cook, Vic
    You wouldnt have to have the opening right behind the intercooler. The air just needs someone to flow to. It could be anywhere in front of or behind the wheel
    May 2011
    CAMPBELLTOWN
    Find a decent SMIC, one that has Good flow for Air in.
    and Do the Audi TT Vent whilst you at it =)
    Perfecto
    GIAC | FORGE | D2 | TURBOSMART | K&N | XFORCE |
    After seeing that core, if you could get one in the right orientation, I think it would be great. From previously reading a lottt of threads on the pog coolers, the main issue seems to be heat soak robbing power. The larger Forge FMIC units have a slight pressure drop while the APR ones are slightly more efficient, but both have longer pipe runs. If an upgraded SMIC held off heat soak comparable to an FMIC then I think it would be a winner.
