Turbosmart Kompact BOV/Reciirc valve
HI Guys , just installed a plumback 25mm Kompact valve.
Will post picks tomorrow,
So far it feels like boost is a bit crisper but not much else. Happy with it as it was only $160
According to the instructions it is meant to be installed opposite to how the standard one was installed, that is with boost pushing against the cylinder. I thought better of this given how the standard one is fitted.
Anyone have any thoughts on whether or not I have installed correctly?
Install as per manual. Some can be run 'backwards', which is in the stock orientation. I run mine this way, but the difference is negligible.
There are threads all over on the topic with comments from it wont work to its better. Have a go if you're game.
- You may not post replies
- You may not edit your posts
Forum Rules
