Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 65
Thread: GTI running too cool?
  1. #21
    Feb 2014
    Gold Coast, Queensland
    Can anyone recommend a good place to buy one and what sort of price I'm looking at for a replacment. Just to clarify, on a cold night or morning (around 10-12 celcius) the car should still be sitting at 90C? It seems like sitting on 70C when driving with the air temps being that low and passing thought the engine bay and cooling the engine would be normal or am I way off?
  2. #22
    Sep 2012
    Wonga Park, VIC
    found heaps on ebay from uk for cheap
  3. #23
    Quote Originally Posted by louis19 View Post
    Should always be 90 degrees. The stat regulates the flow to make this happen. If the water gets hot, it opens prompting flow through the radiator and getting it cooled more and vice versa.
  4. #24
    Feb 2014
    Awesome thanks for the info mate! Looks like its time to replace the stat then. Anyone know where I can find a DIY tutorial to do this? Would VW stock the thermostat?
  5. #25
    They would, be pricey from there though. Have a look around the internet first.
  6. #26
    Feb 2014
    Is one like this suitable? Or is there a particular make or brand that is good to try and go for.
    Other then the thermostat itself is the only other thing I will need is coolant mixture?
    Facet Thermostat Volkswagen Polo 1 8 GTI 2001 2009 | eBay
    Thanks!
  7. #27
    Thanks!
    I consider that pricey but it is the right one. Note what I said to Stuwey early on about the plastic housing it sits behind.
  8. #28
    Feb 2014
    What would you consider a good price? Searching everywhere I can find, and the one I linked above is about the standard price on eBay, there's others cheaper internationally but are charging the remaining difference in postage so it's effectively the same price. On top of the thermostat I'm going to need new coolant correct? And if possible, an extra plastic casing? Any ideas what the casing is actually called so I can try and find one?
    Thanks!
  9. #29
    Thanks!
    FOR Audi VW Jetta 4 Cylinder 1 8 2 0 Thermostat Housing Cover Water Outlet Pipe | eBay
    I have one at home. Just when you are battling with it, there's a slight danger of breaking it. Usually on a Saturday afternoon. No need to buy one every time, if you break yours, you can have mine and replace it.
    Thermostat 87C VW Golf Beetle Jetta Passat Audi A4 TT | eBay
    vw golf thermostat | eBay
    You could reuse the coolant and just top up what you lose. I find the problem with old coolant is how to dispose of it.
    Warm the engine and drop it out of the radiator drain on the passenger side. Use some G12.
  10. #30
    Feb 2014
    Awesome thanks for the links and info Gav!
