GTi rear bump stops
Hi folks, been browsing this forum for a while bu think this is my first post!
Anyways, i'm after some information! My Polo had its first MOT the other day and i've been told i need to replace my rear bump stops!!! I'm currently lowered 35mm on H&R springs so thought upgrading the bump stops would be worthwhile now!!! So can you clever folks tell me what the dimensions are for the rear bump stops so i can see if Powerflex make any suitable!!?? Or do you lot recommend another company??? Or shall i just get some more standard ones???
Thanks, Mat
are you still on stock shocks with those springs?
from what i gather its best to replace the shocks so you don't hit the bump stops after the H&R springs are installed
did you shocks hold up? apparently 5000kms after H&R springs, they might die
your thoughts?
Yeah, still running on stock shocks but rear are now in need of replacing!!!
Want to upgrade but not sure whats out there to upgrade too!!!
Many threads on this...Bilstein B8's is what your after according to many on here
i was going to throw in springs only also but i think they shocks need to be done simultaneously
- You may not post replies
- You may not edit your posts
Forum Rules
