I usually just remove the caliper from the hub and do it with the caliper/carrier in one piece once you remove the spring clip - can get a bit busy/heavy but it works for me.
If I wanted to swap between different pads and rotors for road and track use, are the caliper to carrier bolts reuseable or do need to source a new set of 4 each time I do a swap?
Resident grumpy old fart
Cheap, Fast, Reliable. Choose two.
Do you have the GTI style calipers Greg? With 2 13mm bolts holding the caliper to the carrier? Personally I wouldn't sweat reusing them. But if you are worried, go to a bolt shop and get some new ones and some thread lock.
EDIT seen you have GTI calipers now I read it properly....![]()
The front carrier (190Nm) & slider (30Nm) bolts are re-usable.
The rear caliper carrier and the slider bolts should be replaced every time (in theory). You can probably get 2 or 3 tightens out of them or simply replace with grade 8 std bolts
Isn't that the rear brake?
