Results 1 to 9 of 9
Thread: GTi front brake caliper bolt reusable?
    Oct 2010
    Melbourne, VIC
    If I wanted to swap between different pads and rotors for road and track use, are the caliper to carrier bolts reuseable or do need to source a new set of 4 each time I do a swap?
    Resident grumpy old fart
    I usually just remove the caliper from the hub and do it with the caliper/carrier in one piece once you remove the spring clip - can get a bit busy/heavy but it works for me.
    Cheap, Fast, Reliable. Choose two.
    Quote Originally Posted by kaanage View Post
    Do you have the GTI style calipers Greg? With 2 13mm bolts holding the caliper to the carrier? Personally I wouldn't sweat reusing them. But if you are worried, go to a bolt shop and get some new ones and some thread lock.
    EDIT seen you have GTI calipers now I read it properly....
    Erskineville, NSW
    The front carrier (190Nm) & slider (30Nm) bolts are re-usable.
    The rear caliper carrier and the slider bolts should be replaced every time (in theory). You can probably get 2 or 3 tightens out of them or simply replace with grade 8 std bolts
    ^ this. If you plan on changing brake pads often then just get new bolts (non-stretch bolts).
    Oct 2010
    Melbourne, VIC
    Which are these?
    Erskineville, NSW
    Oct 2010
    Melbourne, VIC
    Isn't that the rear brake?
    Erskineville, NSW
    Yes it is. Read my post again. Para1 is fronts; para 2 is rears
