80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
You shouldn't have too much of a problem then, just as suggested before you will need in the least, 15's with some significant clearance for the larger calipers or 16's just to be on the safe side
i'm pretty sure all the 9n3 polos are 5 stud. any clues as to what you're going to need gti brakes for?
i'm guessing you've got the stock 14' steelies? do you have discs brakes at the back? you might have more of an issue fitting gti rear brakes if you have drums
assuming this, the rears would probably require new longer hand brake cables (gti e-brake cables). otherwise it should be a pretty much bolt on - bleed - drive away affair.
87' MK2 GTI
13' MK7 TDI
Are you sure Blitzen? All the polos on here have 5 studs:
http://www.volkswagen.com.au/vwcms/m...Cars/polo.html
i sold my wheels to a bloke with a polo match. they were 5 studs.
Just to let everyone know,
They dont fit unless you swap over the Stub Axles too.
