Results 11 to 20 of 35
Thread: Gt2860r
    May 2009
    S.E. Melb Vic
    440's troy w/ giac and backing the pressure off to 37/38 psi which is still pumping 27 to 30 lbs boost peak and 22/24 constant and feeling every moment of it.
    Sep 2010
    Wheelers Hill
    F21 does look very tempting, i think there rated to 260hp on stock internals which is impressive
    Audi A3 1.8 T
    aiming for 200kw atw
    http://www.vwwatercooled.com.au/foru...-8t-71747.html
    Oct 2010
    Melbourne, VIC
    Back to the OT, a disco potato in a Polo would probably come in pretty late and savagely. You might need the 2.0 stroker kit to help it spool (or if you really are chasing big numbers, then the low compression stroker kit).
    Did you plan for an LSD/TDB to go with the engine/clutch mods?
    Resident grumpy old fart
    May 2009
    S.E. Melb Vic
    Njay, What franken are you running with yours?
    Sep 2010
    Wheelers Hill
    ive got a f23 going in, engine is at the machinist at the moment to bore for bigger pistons and balance the crank, new rods and pistons
    Audi A3 1.8 T
    May 2009
    S.E. Melb Vic
    can wait to here the results of this
    Sep 2010
    Wheelers Hill
    any idea what your pushing at the moment?
    the polo guys are really going hard compared to the agu bunch
    Audi A3 1.8 T
    May 2009
    S.E. Melb Vic
    on full boost it feels 200 plus but lets wait and see what the dyno says my last dyno was 146.7 and this feels totly different
    Scarly different
    Jan 2009
    Sam, what's your end goal for the car mate, run quarter mile, highway runs or circuit?
    If it's a top-end style of turbo (i.e. larger) on a 1.8l, would that mean needing more revs to get the most out of it, so a 7k rev limit or something.
    Daily: 2010 VW Jetta Highline
    Jun 2009
    Quote Originally Posted by seangti View Post
    I was thinking the same thing.
    To be honest unless you are going to make this thing into a proper track car there is really no point in going to a much larger turbo as happy laps won't allow its full potential.
    Sean's car hammers around lakeside and regularly keeps pace with the more powerful cars.
