Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Groaning/Squeaking Suspension
    Nov 2008
    Wembley, WA
    It would seem that there is obviously several places where these creaks & squeaks seem to eminate from. I guess a mechanic is the best bet for a proper diagnosis.
    Dec 2008
    South Africa
    The sound came back again this weekend… most evident between 60-80 KMH..
    This morning quite as a snake… whats going on???
    Ive booked it in for later this week
    Essendon
    I get a squeak/rattle that seems to be coming from the rear right wheel area, maybe spring or suspension thing. But it comes and goes, depending on ambient temperature. The colder it is, the more obvious the noise.
    Sunroof // ICT Tint // Seats // Steering wheel
    Dec 2008
    South Africa
    hi all,
    have confirmed with the dealership its something with the suspension.. weird my susp is still stock, maybe its the cold weather cause as it has been getting warmer nowadays i noticed it squeaking less...
    Melbourne, Victoria
    Is it definitely coming from your suspension?
    I had a noise I assumed was in the dash / door, fixed by VW but apparantly was the radiator mounts...
    I've recently had my radiator and front brake rotars replaced. Ever since, I've been hearing a squeak (only when the engine is warm) coming from the front of my car somewhere.
    VW diagnosed it as the brake rotors (being after market), but I had them replaced with originals yesterday. I can still hear a squeak, usually when I de-cellerate in high gear, turning slightly left or right or going over small dips on a road. I'm thinking it must be related to when I had my radiator replaced and after reading your post, the radiator mounts. Was this the same problem you had?
    Jan 2009
    blankedy
    Sounds different mate, has it changed at all? Can you give more detail?
    Melbourne, Victoria
    All sorted now. I took it back and the problem was a loose on the calipers. Glad I can drive without that annoying squeak sound.
    May 2011
    Albury, NSW
    I'm also getting the occasional groan from the suspension when driving the car for the first time in a couple of days - it's garaged for anywhere between 5-10 days and the first drive afterwards is always groan-tastic.
    I'm on stock everything so no idea what it is! Only been noticing it during the colder months though, so I'm jumping to the same conclusion as everybody else.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Jun 2009
    Malaysia
    Hi There,
    Did you managed to find the root cause? I'm on stock and had a similar "ambient-temperature" prone squeak on my rear left. I've tried removing the rear suspension, remoce the under-fender trim and couldn't find the cause. But after removal of the under-fender trims, i realised the rear fender seems to have 2 layers of metal. there could be wiring running through the metals that expand/contract when the temp changes....now still figuring out how to remove the trims to find the root cause...
    Jan 2009
    sunshine coast
    my suspension (well what i thaught was my suspension) started squeaking about a year back, turned out it was the after market sway bar bushes. i just got them to tighten them up at the dealership. could it be the stock bushes being the root cause?
    " I wait I resolution derive pleasure this " latest spammer post
